Introduction
The Sony Xperia Z Ultra Android smartphone was released in 2013 and the sleek design can lead to screen issues. This guide details the removal of the screen.
Use the small suction cup to lift the back panel:
Press the small suction cup on to the middle of the back panel.
While holding the Sony Xperia Z ultra down with your left hand, slightly pull the small suction cup upwards to create a small opening between the back panel and the front panel.
While continuing to pull the small suction cup upwards, insert the spudger in the small opening.
Pry the front panel downwards with the spudger while continuing to pull the small suction cup upwards.
Detach the headphone jack connection by prying it upwards with the spudger.
The front camera remove step seems missing
I also think you missed the bit about detaching the connector at the bottom right of the mother board. Also you forgot to mention not to pry the motherboard up and away by going anywhere near the ribbon. The area near the ribbon needs to be avoided at all costs - I have just destroyed my Z Ultra by detaching the glued ribbon. You need a microscope and special glue and tape if you do what I have done.
Detach the upper end of the motherboard by pulling the top end upwards.
Don’t go anywhere near the ribbon when trying to pry the motherboard off. I have just detached the glued on ribbon and destroyed my phone.
Push the red stopper of the headphone jack connection through the plastic tunnel with the spudger.
While holding the back end of the headphone jack connection, grasp the headphone jack connection with the pair of tweezers and guide it through the plastic tunnel.
Remove the headphone jack connection from the device.
Using the spudger, detach the listening speaker from the motherboard by prying it upwards.
To reassemble the device, follow these instructions in reverse order.
30 other people completed this guide.
14 Comments
The directions are wrong. The steps are not in order. The ribbon cable will rip on you when you remove the battery. Do not attempt.
Ribbon cable will not be ripped when removing battery, check to make sure you have carefully broken the adhesive seal between the battery and phone housing.
There is absolutely no reason to take out anything other than the battery and the small parts at the bottom of the phone if you are replacing the display assembly on this device. Taking out anything at the top is a waste of time, and a risk to the motherboard. The metal shield at the bottom is really the only thing you need to remove to get to the digitizer connector. Taking anything else out results in wasted time and additional risk to damage of other components.
A hundred times this. The button flex cables on Sony phones are very easy to damage, and there is absolutely no reason to remove them just to replace the display. Unless your display assembly came with a complete frame. Then you have bigger worries, and this guide is incomplete.
Great instructions thanks and it would be even greater if you mentioned that you didnt have to remove flex cables for volume keys or even motherboard
The last paragraph on step 36 reads "There is adhesive between the screen and casing."
Then there's a final note that reads "To reassemble your device, follow these instructions in reverse order."
Don't we need to replace the adhesive mentioned before to put everything back together?
What kind of adhesive is it and where can I buy it?
My z3+ touch was replaced and now sometimes touch getting hanging, top sensor light not working, double touch not working. Kindly advise why it's happening??????
This should be retitled to Sony Xperia Z Ultra Disassembly - not Screen Replacement - as there was no actual screen replacement that happened!
Replacing an XZU screen is straightforward and quite easy.
thank you and please don’t remove this page.
thank you. I will try
thank you . great instructions.
