Sony Xperia XA2 Ultra Cameras Replacement
  1. Sony Xperia XA2 Ultra Cameras Replacement, Rear Cover: step 1, image 1 of 2 Sony Xperia XA2 Ultra Cameras Replacement, Rear Cover: step 1, image 2 of 2
    • Turn off your phone before continuing.
    • Remove the SIM card tray on the left side of the phone using a SIM card eject tool.
  2. Sony Xperia XA2 Ultra Cameras Replacement: step 2, image 1 of 1
    • Heat the edge of the phone with the heat gun (recommended) for 30 seconds.
    • If you don't have a heat gun, a hair dryer can be used.
    • Use the hair dryer on the highest setting, constantly going around the phone to heat all of the edges.
    • The phone will become hot to the touch. Use gloves or a towel to touch the phone.
  3. Sony Xperia XA2 Ultra Cameras Replacement: step 3, image 1 of 2 Sony Xperia XA2 Ultra Cameras Replacement: step 3, image 2 of 2
    • Apply the suction handle near an edge of the phone and pull upwards while trying to get an opening large enough for an iFixit opening pick.
  4. Sony Xperia XA2 Ultra Cameras Replacement: step 4, image 1 of 2 Sony Xperia XA2 Ultra Cameras Replacement: step 4, image 2 of 2
    • Pry upwards with the pick to start pulling the rear cover off the adhesive it’s attached to.
    • Insert a second pick once there is enough room.
  5. Sony Xperia XA2 Ultra Cameras Replacement: step 5, image 1 of 2 Sony Xperia XA2 Ultra Cameras Replacement: step 5, image 2 of 2
    • Take one of the picks and try to slide it down the side of the phone, pulling more of the cover off the adhesive.
    • The iFixit opening tool may also be used to gain better leverage.
    • The rear cover will pop off.
  6. Sony Xperia XA2 Ultra Cameras Replacement: step 6, image 1 of 1
    • Once the rear cover is off, use the iFixit opening tool to detach the flex cable.
  7. Sony Xperia XA2 Ultra Cameras Replacement, Motherboard Bracket: step 7, image 1 of 2 Sony Xperia XA2 Ultra Cameras Replacement, Motherboard Bracket: step 7, image 2 of 2
    • Remove the six 3 mm Phillips #000 screws.
  8. Sony Xperia XA2 Ultra Cameras Replacement: step 8, image 1 of 1
    • Remove the motherboard bracket with an iFixit opening tool.
  9. Sony Xperia XA2 Ultra Cameras Replacement, Motherboard: step 9, image 1 of 1
    • Using the Jimmy, remove the two antenna flex cables.
  10. Sony Xperia XA2 Ultra Cameras Replacement: step 10, image 1 of 2 Sony Xperia XA2 Ultra Cameras Replacement: step 10, image 2 of 2
    • Using the iFixit opening tool, pry and remove the motherboard.
  11. Sony Xperia XA2 Ultra Cameras Replacement, Cameras: step 11, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the rear-facing camera.
    • Use a pair of tweezers to remove the magnetic tape covering the front-facing camera.
    • Use a pair of tweezers to remove the front-facing camera.
Kristen Gismondi
82,698 Reputation
202 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 71
