Sony Walkman NWZ-E438 Screen Replacement
  1. Sony Walkman NWZ-E438 Screen  Replacement, Disassembling Sony Walkman NWZ-E438: step 1, image 1 of 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Screen  Replacement: step 2, image 1 of 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Screen  Replacement, Screen: step 3, image 1 of 1
    • Pull up the 2 copper strips connecting the outside of the device to the inside of the device.
  4. Sony Walkman NWZ-E438 Screen  Replacement: step 4, image 1 of 1
    • Using the small, plastic prying tool wedge it between the bottom of the frame and the outer frame.
    • Slowly circle the device, popping the outside of the frame off.
  5. Sony Walkman NWZ-E438 Screen  Replacement: step 5, image 1 of 1
    • To remove the screen, use the fine point tweezers and lift up on the metal piece at the bottom of the frame.
  6. Sony Walkman NWZ-E438 Screen  Replacement: step 6, image 1 of 1
    • To remove screen from metal backing, use fine point tweezers to go in between the screen and metal backing and slowly pull them apart.
  7. Sony Walkman NWZ-E438 Screen  Replacement: step 7, image 1 of 1
    • The screen will be removed.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 687
