Introduction
This guide will take you through 4 simple steps to removing your circuit board. For reattachment, simply follow the steps in reverse order.
Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
First, you must remove the black tape on the circuit board.
Next, pull up on the red and gold band until it detaches from the chip.
Using a small plastic prying tool, slip the end under the device circuit board and slowly lift it.
Once the circuit board is lifted, carefully remove the chip with tweezers.
Using a soldering iron, carefully heat the metal connecting the wires from the device to the circuit board.
