Sony Walkman NWZ-E438 Device Circuit Board Replacement
  1. Sony Walkman NWZ-E438 Device Circuit Board Replacement, Disassembling Sony Walkman NWZ-E438: step 1, image 1 of 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Device Circuit Board Replacement: step 2, image 1 of 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Device Circuit Board Replacement, Circuit Board: step 3, image 1 of 3 Sony Walkman NWZ-E438 Device Circuit Board Replacement, Circuit Board: step 3, image 2 of 3 Sony Walkman NWZ-E438 Device Circuit Board Replacement, Circuit Board: step 3, image 3 of 3
    • First, you must remove the black tape on the circuit board.
    • Next, pull up on the red and gold band until it detaches from the chip.
  4. Sony Walkman NWZ-E438 Device Circuit Board Replacement: step 4, image 1 of 2 Sony Walkman NWZ-E438 Device Circuit Board Replacement: step 4, image 2 of 2
    • Using a small plastic prying tool, slip the end under the device circuit board and slowly lift it.
    • Once the circuit board is lifted, carefully remove the chip with tweezers.
    • The circuit board will still be connected to the device by a wire.
  5. Sony Walkman NWZ-E438 Device Circuit Board Replacement: step 5, image 1 of 1
    • Using a soldering iron, carefully heat the metal connecting the wires from the device to the circuit board.
    • You will need the soldering iron to reattach those wires once you've replaced the circuit board.
  6. Sony Walkman NWZ-E438 Device Circuit Board Replacement: step 6, image 1 of 1
    • Carefully remove the circuit board from the device.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 16
All Time: 530
