Sony Walkman D-EJ360 Laser Module Replacement
    1. Sony Walkman D-EJ360 Laser Module Replacement, Lid: step 1, image 1 of 1
      • Open the lid on the Walkman by pressing the open button on the device.
      Ask FixBot
    2. Sony Walkman D-EJ360 Laser Module Replacement: step 2, image 1 of 3 Sony Walkman D-EJ360 Laser Module Replacement: step 2, image 2 of 3 Sony Walkman D-EJ360 Laser Module Replacement: step 2, image 3 of 3
      • Grip the thin end of each spring using a pair of tweezers, slide it out of the lid notch, then press down on the main coil to release and remove it.
      Ask FixBot
    3. Sony Walkman D-EJ360 Laser Module Replacement: step 3, image 1 of 3 Sony Walkman D-EJ360 Laser Module Replacement: step 3, image 2 of 3 Sony Walkman D-EJ360 Laser Module Replacement: step 3, image 3 of 3
      • Insert the metal spudger in the crevice between the blue lid and the white body of the Walkman.
      • There is a notch where the lid is held under to stay in place. With the spudger, push the blue lid portion down and out.
      • This may require some harder force. You will hear a popping sound when you successfully push the lid out under the notch.
      • Repeat the same tactic on the other side. The other side should become easier to pop off.
      • Remove the lid.
      Ask FixBot
    1. Sony Walkman D-EJ360 Laser Module Replacement, Laser Module: step 4, image 1 of 2 Sony Walkman D-EJ360 Laser Module Replacement, Laser Module: step 4, image 2 of 2
      • Remove the eight 6.1 mm screws using a Phillips #00 screwdriver.
      • Open the battery cover to reveal the last screw.
      • Remove the ninth 6.1 mm screw using a Phillips #00 screwdriver.
      Ask FixBot
    2. Sony Walkman D-EJ360 Laser Module Replacement: step 5, image 1 of 2 Sony Walkman D-EJ360 Laser Module Replacement: step 5, image 2 of 2
      • Insert a Jimmy into the seam between the upper and lower cases and pry apart.
      • Avoid initially prying near buttons, or the laser assembly.
      • Pry until the there is an audible click. The halves should visibly separate roughly 1/4 in.
      • Work around the seam in a circular path, separating the halves completely.
      • The motherboard and turn table module are only held in by gravity in the blue shell. Do not tip the device while separating the shells.
      Ask FixBot
    3. Sony Walkman D-EJ360 Laser Module Replacement: step 6, image 1 of 2 Sony Walkman D-EJ360 Laser Module Replacement: step 6, image 2 of 2
      • Using tweezers, gently lift the the locking flap on the laser module ribbon connector.
      • Gently remove the ribbon cable from the connector.
      Ask FixBot
    4. Sony Walkman D-EJ360 Laser Module Replacement: step 7, image 1 of 3 Sony Walkman D-EJ360 Laser Module Replacement: step 7, image 2 of 3 Sony Walkman D-EJ360 Laser Module Replacement: step 7, image 3 of 3
      • Using tweezers, squeeze the upper half of the four wire connector, and lift straight up to remove the connector.
      • The connector may make a tactile click when disengaged.
      • Repeat the step for the two wire connector.
      Ask FixBot
    5. Sony Walkman D-EJ360 Laser Module Replacement: step 8, image 1 of 2 Sony Walkman D-EJ360 Laser Module Replacement: step 8, image 2 of 2
      • Ensure the ribbon cable, two, and four wire cables are all removed and not tangled with the motherboard.
      • Gently lift the laser module and place aside.
      Ask FixBot
Kristen Gismondi
109,388 Reputation
271 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 82
All Time: 420
