Introduction
This guide will inform readers on how to safely remove the fan of the Sony VAIO VPC-EB33FM laptop for replacement.
Parts
Power down the laptop by pressing the power button.
Turn the laptop onto its backside.
Remove all charge from the laptop by holding down the power button for at least 5 seconds.
Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel.
Grab the tab between your thumb and index finger.
Hold the hard drive securely in a horizontal position using your other hand.
Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
Pull the hard drive out.
If you need to remove the bracket from the hard drive, follow the next few steps:
Remove the two 3.67-mm screws from either side of the bracket with a Phillips #00 screwdriver.
Lift the bracket off the hard drive.
Pull the two retaining arms away from the center of the RAM chip.
The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
Pull the RAM stick out of its socket.
To remove the second stick of RAM, repeat steps six and seven.
When installing RAM, make sure sticks are firmly in place or the computer will not register them.
Remove the following 16 screws securing the back cover using a Phillips #00 screwdriver:
Two 3.8-mm screws
Two 8.9-mm screws
Twelve 7.75-mm screws
Using both hands, separate the back cover by lifting from the back and working around the perimeter to release tabs.
Remove the two 5.7-mm screws located at the base of the fan, using a Phillips #00 screwdriver.
Position thumbs and index fingers close to processor and lift up on the copper wire, while applying slight downward pressure on the motherboard with remaining fingers.
