Sony SRS-XE200 Speaker Assembly Replacement
  1. Sony SRS-XE200 Speaker Assembly Replacement, Speaker Assembly: step 1, image 1 of 2 Sony SRS-XE200 Speaker Assembly Replacement, Speaker Assembly: step 1, image 2 of 2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Speaker Assembly Replacement: step 2, image 1 of 1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Speaker Assembly Replacement: step 3, image 1 of 2 Sony SRS-XE200 Speaker Assembly Replacement: step 3, image 2 of 2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Speaker Assembly Replacement: step 4, image 1 of 2 Sony SRS-XE200 Speaker Assembly Replacement: step 4, image 2 of 2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
Kristen Gismondi
83,559 Reputation
205 Guides authored
iFixit Member of iFixit
Staff
138 Members
17,679 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 16
All Time: 156
