Sony RDR HX750 HX950 Disassembly
  1. Sony RDR HX750 HX950 Disassembly, Remove Sony RDR HX750 cover: step 1, image 1 of 3 Sony RDR HX750 HX950 Disassembly, Remove Sony RDR HX750 cover: step 1, image 2 of 3 Sony RDR HX750 HX950 Disassembly, Remove Sony RDR HX750 cover: step 1, image 3 of 3
    • Remove Screws from back and sides
  2. Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: step 2, image 1 of 3 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: step 2, image 2 of 3 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: step 2, image 3 of 3
    • Remove the screws that old hard drive
    • Unplug the cables from disk
    • Remove screws from back side of hard drive
  3. Sony RDR HX750 HX950 Disassembly, Remove DVD player: step 3, image 1 of 3 Sony RDR HX750 HX950 Disassembly, Remove DVD player: step 3, image 2 of 3 Sony RDR HX750 HX950 Disassembly, Remove DVD player: step 3, image 3 of 3
    • Remove Screws from dvd cover
    • Remove screws from plastic cable holder
  4. Sony RDR HX750 HX950 Disassembly, Remove front Panel: step 4, image 1 of 3 Sony RDR HX750 HX950 Disassembly, Remove front Panel: step 4, image 2 of 3 Sony RDR HX750 HX950 Disassembly, Remove front Panel: step 4, image 3 of 3
    • Inser litle paper under each "click" to remove front panel.
    • When each "click" is lose, puch front panel gently, it will go out easily.
    • The table of compac disk has a little plastic in front that goes out "up" with a "click"
  5. Sony RDR HX750 HX950 Disassembly, Remove  DVD block: step 5, image 1 of 3 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: step 5, image 2 of 3 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: step 5, image 3 of 3
    • Unplug the cables show on foto.
    • Desconect this cable hided on the side.
    • Remove the little piece on cd reader, It has a click.
  6. Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: step 6, image 1 of 3 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: step 6, image 2 of 3 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: step 6, image 3 of 3
    • Under the dvd block remove screws
    • Then remove screws on board
    • Now you can access the laser
  7. Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: step 7, image 1 of 3 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: step 7, image 2 of 3 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: step 7, image 3 of 3
    • Inserir instruções aqui.
Cafony
687 Reputation
4 Guides authored
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 58
All Time: 5,428
