Sony Handycam DCR-DVD103 Outer Cover Replacement
  1. Sony Handycam DCR-DVD103 Outer Cover Replacement, Battery: step 1, image 1 of 1
    • Images do not show the camera's battery.
    • On the back of the camera beneath the viewfinder, locate the battery pack.
    • Press the small button.
    • Slide the switch forward.
  2. Sony Handycam DCR-DVD103 Outer Cover Replacement: step 2, image 1 of 1
    • Remove the battery from the camera.
    • To reinsert the battery, slide the battery into the camera.
  3. Sony Handycam DCR-DVD103 Outer Cover Replacement, Outer Cover: step 3, image 1 of 1
    • Remove the (6) 4.5mm screws from the bottom of the Sony Handycam that are marked with small circles.
    • Note: You will use the #00 Philips Screwdriver for this part and in all subsequent slides.
    • Note: Most screws that are meant to be removed are marked with arrows on the camera itself.
  4. Sony Handycam DCR-DVD103 Outer Cover Replacement: step 4, image 1 of 2 Sony Handycam DCR-DVD103 Outer Cover Replacement: step 4, image 2 of 2
    • Remove (3) 4.5mm screws from underneath the battery. Again they are marked by small arrows.
    • Remove (1) 2.9mm screw from the right corner.
    • Remove (2) 4.5mm screws from the battery right wall.
    • Note: The battery has been removed for these steps.
  5. Sony Handycam DCR-DVD103 Outer Cover Replacement: step 5, image 1 of 1
    • Remove (1) 4.5mm screw from underneath the output flap on the front of the camera right below the lens.
  6. Sony Handycam DCR-DVD103 Outer Cover Replacement: step 6, image 1 of 2 Sony Handycam DCR-DVD103 Outer Cover Replacement: step 6, image 2 of 2
    • Remove the (2) 4.5mm screws from the top of the camera that are pointed out with red circles.
    • Remove the (1) 4.5 mm screw from the disk side of the camera located next to the lens. This screw is pointed out with a yellow circle.
  7. Sony Handycam DCR-DVD103 Outer Cover Replacement: step 7, image 1 of 2 Sony Handycam DCR-DVD103 Outer Cover Replacement: step 7, image 2 of 2
    • Extend the gray viewfinder so the black, plastic casing will have room to come off.
    • Remove the black plastic casing gently from the top of the camera. Use caution because the plastic pieces are fragile and tend to break easily.
  8. Sony Handycam DCR-DVD103 Outer Cover Replacement: step 8, image 1 of 1
    • Remove (2) 2.9mm screws from under the black plastic casing that was mentioned in the previous step.
  9. Sony Handycam DCR-DVD103 Outer Cover Replacement: step 9, image 1 of 1
    • Caution: Carefully pull off the outer silver case along with screen.
    • Note: The copper wire strip still connecting the cover to the body of the camera must be removed. It is pointed out with a red square in the slide.
kaitlin
342 Reputation
3 Guides authored
Cal Poly, Team 7-44, Regan Winter 2011 Member of Cal Poly, Team 7-44, Regan Winter 2011
CPSU-REGAN-W11S7G44
5 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 2,457
