Installing Sony Handycam DCR-DVD103 LCD Screen
  1. Installing Sony Handycam DCR-DVD103 LCD Screen, Battery: step 1, image 1 of 1
    • Images do not show the camera's battery.
    • On the back of the camera beneath the viewfinder, locate the battery pack.
    • Press the small button.
    • Slide the switch forward.
  2. Installing Sony Handycam DCR-DVD103 LCD Screen: step 2, image 1 of 1
    • Remove the battery from the camera.
    • To reinsert the battery, slide the battery into the camera.
  3. Installing Sony Handycam DCR-DVD103 LCD Screen, Outer Cover: step 3, image 1 of 1
    • Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
  4. Installing Sony Handycam DCR-DVD103 LCD Screen: step 4, image 1 of 2 Installing Sony Handycam DCR-DVD103 LCD Screen: step 4, image 2 of 2
    • Remove the three 4.5 mm screws beneath the battery.
    • Remove the 2.9 mm screw from the right corner.
    • Remove the two 4.5 mm screws from the battery's right wall.
    • Images do not show the battery.
  5. Installing Sony Handycam DCR-DVD103 LCD Screen: step 5, image 1 of 1
    • Remove the 4.5 mm screw under the output flap on the front of the camera below the lens.
  6. Installing Sony Handycam DCR-DVD103 LCD Screen: step 6, image 1 of 2 Installing Sony Handycam DCR-DVD103 LCD Screen: step 6, image 2 of 2
    • Remove the two 4.5 mm screws at the top of the camera.
    • Remove the 4.5 mm screw from the disk side of the camera (next to the lens).
  7. Installing Sony Handycam DCR-DVD103 LCD Screen: step 7, image 1 of 2 Installing Sony Handycam DCR-DVD103 LCD Screen: step 7, image 2 of 2
    • Extend the gray viewfinder, then gently remove the black plastic casing.
    • Caution: Plastic pieces are fragile.
  8. Installing Sony Handycam DCR-DVD103 LCD Screen: step 8, image 1 of 1
    • Remove the two 2.9 mm screws under the black plastic casing.
  9. Installing Sony Handycam DCR-DVD103 LCD Screen: step 9, image 1 of 1
    • Gently pull apart the outer silver case and screen.
    • Remove the copper wire strip to detach the case from the camera.
  10. Installing Sony Handycam DCR-DVD103 LCD Screen, LCD Screen: step 10, image 1 of 1
    • Remove the copper strip holding that connects the outer casing to the entire of the camera.
    • Use caution when removing the wire because if to much force is used it may tear.
  11. Installing Sony Handycam DCR-DVD103 LCD Screen: step 11, image 1 of 3 Installing Sony Handycam DCR-DVD103 LCD Screen: step 11, image 2 of 3 Installing Sony Handycam DCR-DVD103 LCD Screen: step 11, image 3 of 3
    • Remove (4) 2.9mm screws from the L-shaped circuit board. They are marked with red circles in the slide.
    • Remove the (3) wire strips connected to the camera so you can pull off the L-shaped circuit board.
    • Remove the one wire strip that is connected to the bottom of the circuit board.
  12. Installing Sony Handycam DCR-DVD103 LCD Screen: step 12, image 1 of 1
    • Remove the (2) 4.5mm screws.
    • Remove the small black holder from above the base of the LCD screen.
  13. Installing Sony Handycam DCR-DVD103 LCD Screen: step 13, image 1 of 1
    • Remove (1) 2.9mm screw from the base of the LCD screen.
  14. Installing Sony Handycam DCR-DVD103 LCD Screen: step 14, image 1 of 1
    • Remove the silver and black, front and back casings from the base of the screen.
    • Remove one copper strip from the inside of the bottom case.
  15. Installing Sony Handycam DCR-DVD103 LCD Screen: step 15, image 1 of 1
    • Remove (2) 5.4mm screws, that are holding the screen to the cover, from the base of the LCD.
  16. Installing Sony Handycam DCR-DVD103 LCD Screen: step 16, image 1 of 3 Installing Sony Handycam DCR-DVD103 LCD Screen: step 16, image 2 of 3 Installing Sony Handycam DCR-DVD103 LCD Screen: step 16, image 3 of 3
    • Twist out the screen from the cover.
    • Be careful not to break the casing when trying to get the screen out as it does require some maneuvering.
  17. Installing Sony Handycam DCR-DVD103 LCD Screen: step 17, image 1 of 1
    • Remove (2) 3.8mm screws from the end of the LCD.
  18. Installing Sony Handycam DCR-DVD103 LCD Screen: step 18, image 1 of 1
    • Remove (2) 3.8mm screws from the bottom of the LCD.
  19. Installing Sony Handycam DCR-DVD103 LCD Screen: step 19, image 1 of 2 Installing Sony Handycam DCR-DVD103 LCD Screen: step 19, image 2 of 2
    • Pull off the silver cover on the screen which will reveal the circuit board from behind the screen itself.
    • Pull off the black tape stuck to both sides of the circuit board.
  20. Installing Sony Handycam DCR-DVD103 LCD Screen: step 20, image 1 of 1
    • Remove (3) 4.5mm screws from back-side of the LCD.
  21. Installing Sony Handycam DCR-DVD103 LCD Screen: step 21, image 1 of 3 Installing Sony Handycam DCR-DVD103 LCD Screen: step 21, image 2 of 3 Installing Sony Handycam DCR-DVD103 LCD Screen: step 21, image 3 of 3
    • Remove the (3) copper strips to remove both the screen and the back light.
    • Replace what is broken.
kaitlin
342 Reputation
3 Guides authored
Cal Poly, Team 7-44, Regan Winter 2011 Member of Cal Poly, Team 7-44, Regan Winter 2011
CPSU-REGAN-W11S7G44
5 Members
10 Guides authored
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 22
All Time: 8,067
