Introduction
This is a GSM phone originally introduced by AT&T. The SIM card will likely be an AT&T card; however, when in foreign countries, other SIM cards can be inserted into the phone for compatibility with foreign carriers.
Slide the battery cover off by pushing it away from the camera side of the device.
This may require a good amount of force.
Next remove the battery
Lift it out of the phone using the tab on the battery (marked in the image)
The SIM card holder is now exposed (marked in image).
This will likely already have an existing SIM card in it if the phone has been previously used.
To open this, slide the holder upward (assuming the same orientation as in the image)
Now hinge the SIM card holder down so that it lays flat in the phone.
Slide the plastic holder downwards to lock it in place.
Now the battery and cover can be put back in place.
