Introduction
This guide will assist you in removing the speaker from your Sony Ericsson T68i.
Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
Remove the circuit board and screen from the device.
Use your T6 to remove the 4 screws.
Gently pry it out the speaker located in the screen housing with a small screwdriver or similar tool.
