Introduction
This guide will assist you in removing the microphone from your Sony Ericsson T68i.
Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
Next remove the circuit board and screen from the device.
Use your T6 to remove the 4 screws holding the cover on.
The microphone at the bottom of the rear housing can be levered out using a small screwdriver or any similar tool.
