Sony Ericsson T68i Microphone Replacement
  1. Sony Ericsson T68i Microphone Replacement, Keypad: step 1, image 1 of 2 Sony Ericsson T68i Microphone Replacement, Keypad: step 1, image 2 of 2
    • Remove the battery from the back.
  2. Sony Ericsson T68i Microphone Replacement: step 2, image 1 of 3 Sony Ericsson T68i Microphone Replacement: step 2, image 2 of 3 Sony Ericsson T68i Microphone Replacement: step 2, image 3 of 3
    • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
    • Do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Sony Ericsson T68i Microphone Replacement: step 3, image 1 of 3 Sony Ericsson T68i Microphone Replacement: step 3, image 2 of 3 Sony Ericsson T68i Microphone Replacement: step 3, image 3 of 3
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  4. Sony Ericsson T68i Microphone Replacement: step 4, image 1 of 3 Sony Ericsson T68i Microphone Replacement: step 4, image 2 of 3 Sony Ericsson T68i Microphone Replacement: step 4, image 3 of 3
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
  5. Sony Ericsson T68i Microphone Replacement, Microphone: step 5, image 1 of 3 Sony Ericsson T68i Microphone Replacement, Microphone: step 5, image 2 of 3 Sony Ericsson T68i Microphone Replacement, Microphone: step 5, image 3 of 3
    • Next remove the circuit board and screen from the device.
    • Use your T6 to remove the 4 screws holding the cover on.
  6. Sony Ericsson T68i Microphone Replacement: step 6, image 1 of 3 Sony Ericsson T68i Microphone Replacement: step 6, image 2 of 3 Sony Ericsson T68i Microphone Replacement: step 6, image 3 of 3
    • The board and screen should just pop out at this point.
  7. Sony Ericsson T68i Microphone Replacement: step 7, image 1 of 2 Sony Ericsson T68i Microphone Replacement: step 7, image 2 of 2
    • The microphone at the bottom of the rear housing can be levered out using a small screwdriver or any similar tool.
Tim Dascomb
159 Reputation
7 Guides authored
Cal Poly, Team 26-34, Regan Spring 2010 Member of Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 Members
13 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 2,183
