Sony DSC-RX100MA Back Cover Replacement
  1. Sony DSC-RX100MA Back Cover Replacement, Back Cover: step 1, image 1 of 3 Sony DSC-RX100MA Back Cover Replacement, Back Cover: step 1, image 2 of 3 Sony DSC-RX100MA Back Cover Replacement, Back Cover: step 1, image 3 of 3
    • Remove battery by sliding the tab to open the cover
  2. Sony DSC-RX100MA Back Cover Replacement: step 2, image 1 of 3 Sony DSC-RX100MA Back Cover Replacement: step 2, image 2 of 3 Sony DSC-RX100MA Back Cover Replacement: step 2, image 3 of 3
    • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
    • All screws in the camera can be removed with the PH 0 driver head.
  3. Sony DSC-RX100MA Back Cover Replacement: step 3, image 1 of 3 Sony DSC-RX100MA Back Cover Replacement: step 3, image 2 of 3 Sony DSC-RX100MA Back Cover Replacement: step 3, image 3 of 3
    • Also using the screwdriver, remove screws (black 2.5mm) underneath articulated LCD screen.
    • Remove the marked 1 mm screws with the screwdriver
  4. Sony DSC-RX100MA Back Cover Replacement: step 4, image 1 of 2 Sony DSC-RX100MA Back Cover Replacement: step 4, image 2 of 2
    • Using the plastic opening tools, carefully pry off the bottom plate.
    • Do not pull too hard as you may break the plastic casing.
  5. Sony DSC-RX100MA Back Cover Replacement: step 5, image 1 of 3 Sony DSC-RX100MA Back Cover Replacement: step 5, image 2 of 3 Sony DSC-RX100MA Back Cover Replacement: step 5, image 3 of 3
    • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
    • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
  6. Sony DSC-RX100MA Back Cover Replacement: step 6, image 1 of 2 Sony DSC-RX100MA Back Cover Replacement: step 6, image 2 of 2
    • You can now remove the back cover
KC Egger
291 Reputation
2 Guides authored
Cal Poly, Team 21-1, Maness Winter 2017 Member of Cal Poly, Team 21-1, Maness Winter 2017
CPSU-MANESS-W17S21G1
5 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 47
All Time: 3,067
