Slide the battery latch down the side of the camera with your hands.
The latch will automatically pop open.
Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
Remove the 3.0mm Phillips #000 screw above the battery door on the side of the camera.
Remove the top button piece. You will need to detach a small blue ribbon cable before the button can be fully removed.
