Sony Cyber-shot DSC-P100 Camera Flash Replacement
  1. Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: step 1, image 1 of 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: step 1, image 2 of 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: step 1, image 3 of 3
    • First locate the appropriate screws for detachment.
  2. Sony Cyber-shot DSC-P100 Camera Flash Replacement: step 2, image 1 of 1
    • Remove the five screws shown using a Phillips #00 Screwdriver.
    • It is important to put the small screws in a safe location in order to reassemble the casing.
  3. Sony Cyber-shot DSC-P100 Camera Flash Replacement: step 3, image 1 of 1
    • Using a spudger, carefully pry open the front casing.
  4. Sony Cyber-shot DSC-P100 Camera Flash Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-P100 Camera Flash Replacement: step 4, image 2 of 2
    • Carefully separate the front casing from the camera body.
    • CAUTION: Be careful not to break the wire connecting the front casing and the camera.
  5. Sony Cyber-shot DSC-P100 Camera Flash Replacement, Camera Flash: step 5, image 1 of 2 Sony Cyber-shot DSC-P100 Camera Flash Replacement, Camera Flash: step 5, image 2 of 2
    • Using tweezers, gently pull the ribbon trace out of its housing found on the left side of the flash.
  6. Sony Cyber-shot DSC-P100 Camera Flash Replacement: step 6, image 1 of 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement: step 6, image 2 of 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement: step 6, image 3 of 3
    • Using a spudger, pry the small latch between the lens and the flash open to release the flash.
    • Pull the flash away from the camera.
Katie McCraw
191 Reputation
7 Guides authored
Clemson, Team 1-5, Benson Spring 2012 Member of Clemson, Team 1-5, Benson Spring 2012
CLEM-BENSON-S12S1G5
4 Members
14 Guides authored
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 32
All Time: 2,515
