Sony Alpha NEX-C3 Back Panel Replacement
  1. Sony Alpha NEX-C3 Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Use a Phillips head 000 screwdriver to remove the 4.0mm screw at the side opposite of the USB port.
  2. Sony Alpha NEX-C3 Back Panel Replacement: step 2, image 1 of 2 Sony Alpha NEX-C3 Back Panel Replacement: step 2, image 2 of 2
    • Use a Phillips head 000 screwdriver to remove the three 4.0mm screws on the bottom of the camera.
  3. Sony Alpha NEX-C3 Back Panel Replacement: step 3, image 1 of 1
    • Tilt up the LCD screen.
    • Use a Phillips head 000 screwdriver to remove the two coarse 4.0mm screws near the bottom of the camera.
  4. Sony Alpha NEX-C3 Back Panel Replacement: step 4, image 1 of 1
    • Gently pry off the back panel, by wiggling it around the LCD screen.
Jonathan Chen
690 Reputation
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 862
