Skullcandy Air Raid Front Panel Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Skullcandy Air Raid Front Panel Replacement, Rubber Cover: step 1, image 1 of 1
    • Starting with the corners, gently pull the rubber cover off of the device.
  2. Skullcandy Air Raid Front Panel Replacement, Handle: step 2, image 1 of 1
    • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
    • Remove the handle from the device.
  3. Skullcandy Air Raid Front Panel Replacement, Front Plate: step 3, image 1 of 1
    • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
    • One 5mm Phillips screw.
    • One 8mm Phillips screw.
  4. Skullcandy Air Raid Front Panel Replacement: step 4, image 1 of 1
    • Gently pull the sides of the front plate outwards from the device.
    • Pull up on the front plate to remove it from the device.
Timothy Potts
201 Reputation
2 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 41
