Skullcandy Air Raid Front Panel Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Skullcandy Air Raid Front Panel Replacement, Rubber Cover: step 1, image 1 of 1
      • Starting with the corners, gently pull the rubber cover off of the device.
      Ask FixBot
    2. Skullcandy Air Raid Front Panel Replacement, Handle: step 2, image 1 of 1
      • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
      • Remove the handle from the device.
      Ask FixBot
    3. Skullcandy Air Raid Front Panel Replacement, Front Plate: step 3, image 1 of 1
      • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
      • One 5mm Phillips screw.
      • One 8mm Phillips screw.
      Ask FixBot
    4. Skullcandy Air Raid Front Panel Replacement: step 4, image 1 of 1
      • Gently pull the sides of the front plate outwards from the device.
      • Pull up on the front plate to remove it from the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 15
All Time: 225
