Siemens Synchropower power edition 2400W vacuum cleaner switch replacement
  1. Siemens Synchropower power edition 2400W vacuum cleaner switch replacement, Switch: step 1, image 1 of 3 Siemens Synchropower power edition 2400W vacuum cleaner switch replacement, Switch: step 1, image 2 of 3 Siemens Synchropower power edition 2400W vacuum cleaner switch replacement, Switch: step 1, image 3 of 3
    • Open the cover of the device and remove the 3 Torx screws. Then pry off the two wheels with a flat screwdriver. Now bend open the clip at the marking with the flat screwdriver. Unfortunately it's a bit stiff. The clip on the other side will losen with a little force when you pry off the housing cover.
  2. Siemens Synchropower power edition 2400W vacuum cleaner switch replacement: step 2, image 1 of 3 Siemens Synchropower power edition 2400W vacuum cleaner switch replacement: step 2, image 2 of 3 Siemens Synchropower power edition 2400W vacuum cleaner switch replacement: step 2, image 3 of 3
    • First, I measured the winding of the motor on the black and blue cable. The engine has a passage. I bent the carbon brushes (copper tubes) and checked the length. With 3 cm still like new.
    • I measured the connection cable from the plug to the two contacts on the cable roller. I examined the board for charring, especially the condenser (also for deformation).
    • Finally, I checked the passage at the two solder points of the white switch. That was the problem. There was no contact.
  3. Siemens Synchropower power edition 2400W vacuum cleaner switch replacement: step 3, image 1 of 3 Siemens Synchropower power edition 2400W vacuum cleaner switch replacement: step 3, image 2 of 3 Siemens Synchropower power edition 2400W vacuum cleaner switch replacement: step 3, image 3 of 3
    • The white cover of the switch can be removed very carefully with a flat screwdriver. Then clean the 4 contact points with contact spray and "impregnate" them again with Balistol. Reconnect and check the continuity again.
    • During reassembly, make sure that the rotary switch installed in the housing with its elongated nose slips back into the green marked rotary potentiometer on the board.
    • The clips marked in green will snap back in during assembly. The 3 Torx must be screwed back in.
To reassemble your device follow the steps in reverse order.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Andreas Reheis
2,038 Reputation
16 Guides authored
erfindergarden foundation Member of erfindergarden foundation
Community
5 Members
40 Guides authored
5 Comments
Sehr gute Anleitung hat mir sehr geholfen. Bei mir waren die Kohlebürsten ohne Durchgang, da zu weit vom Motor entfernt. Mit einem Schraubendreher wieder in Position gedrückt, schon läuft der Motor wieder.
Uwe K. - Reply
Wie gut. Viel Freude mit deinem selbstreparierten Staubsauger!
Fabian Neidhardt -
Bei unserem Synchropower 600W war mindestens eine Kohlebürste schon zu kurz und auch die Verbindung zwischen Kupferlitze und Kohlekörper schien unsicher (lösbar gesteckt). Schadensbild war unrunder Lauf und ein unangenehmer, sehr starker Geruch wie Wunderkerze und beim Ansehen nach Demontage ein hellgelber, sehr starker Funkenflug am Kollektor ("Bürstenfeuer").
Für die Demontage reichte bei diesem Modell das Entfernen der drei Torxschrauben, die Räder konnten an der Unterschale verbleiben.
Passende komplette Kohlebürstenträger (Messingrohr mit inliegender, gefederter Kohle) als Ersatzteile habe ich nicht gefunden (intensivere Suche hätte spätere Fummelei erspart), stattdessen passende Kohlen mit verbundener Litze, die ich mit der Litze vom Bürstenträger verlötet habe (dazu vorher die lange Druckfeder mit Blumendraht zum Block zusammengebunden).
Bei offenem Probelauf war nur ein geruchsloses, schwaches, blaues Funkenfeuer zu beobachten, zusammenmontiert. Deswegen leider kein längerer Bericht mit Fotos :(
heschn - Reply
Hatte einen netten Kommentar geschrieben. Der wurde als Spam bezeichnet und rausgeworfen.
Also kein Kommentar!
Klaus - Reply
Hallo Klaus, das tut mir leid mit deinem Kommentar. Unsere Roboter lernen noch. Aber in der Mail müsste eigentlich ein Button gewesen sein, mit dem du angeben kannst, dass das fälschlicherweise als Spam gekennzeichnet wurde.
Fabian Neidhardt -
Past 24 Hours: 8
Past 7 Days: 28
Past 30 Days: 122
All Time: 3,439
