Shure SM58 XLR Microphone Connector Disassembly Replacement
  1. Shure SM58 XLR Microphone Connector Disassembly Replacement, XLR Microphone Connector Disassembly: step 1, image 1 of 1
    • Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
    • The retaining screw is mounted to the connector and has a left-handed thread. Turning the screw clockwise locks the connector in place. Turning it counterclockwise lowers it down into the hole, releasing the connector.
    • Once the screw stops, do not try to loosen it further.
  2. Shure SM58 XLR Microphone Connector Disassembly Replacement: step 2, image 1 of 1
    • Plug an XLR cable into the loose connector.
    • While holding the disconnect button down, pull on the cable to remove the connector from the body of the microphone.
nat coll
642 Reputation
14 Guides authored
Cal Poly, Team 7-53, Forte Fall 2012 Member of Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Members
20 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 102
All Time: 15,170
