Sharp Aquos LC13B2UA Motherboard Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Sharp Aquos LC13B2UA Motherboard Replacement, Stand: step 1, image 1 of 2 Sharp Aquos LC13B2UA Motherboard Replacement, Stand: step 1, image 2 of 2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA Motherboard Replacement: step 2, image 1 of 2 Sharp Aquos LC13B2UA Motherboard Replacement: step 2, image 2 of 2
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA Motherboard Replacement, Back Case: step 3, image 1 of 3 Sharp Aquos LC13B2UA Motherboard Replacement, Back Case: step 3, image 2 of 3 Sharp Aquos LC13B2UA Motherboard Replacement, Back Case: step 3, image 3 of 3
    • Remove the two back panels by prying them out with your hands.
  4. Sharp Aquos LC13B2UA Motherboard Replacement: step 4, image 1 of 2 Sharp Aquos LC13B2UA Motherboard Replacement: step 4, image 2 of 2
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Sharp Aquos LC13B2UA Motherboard Replacement: step 5, image 1 of 1
    • Using your hands, gently lift and remove the back case of the television.
  6. Sharp Aquos LC13B2UA Motherboard Replacement, Motherboard: step 6, image 1 of 3 Sharp Aquos LC13B2UA Motherboard Replacement, Motherboard: step 6, image 2 of 3 Sharp Aquos LC13B2UA Motherboard Replacement, Motherboard: step 6, image 3 of 3
    • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  7. Sharp Aquos LC13B2UA Motherboard Replacement: step 7, image 1 of 2 Sharp Aquos LC13B2UA Motherboard Replacement: step 7, image 2 of 2
    • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
    • Remove the green/gray to orange/gray connector from the center of the circuit board.
  8. Sharp Aquos LC13B2UA Motherboard Replacement: step 8, image 1 of 2 Sharp Aquos LC13B2UA Motherboard Replacement: step 8, image 2 of 2
    • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  9. Sharp Aquos LC13B2UA Motherboard Replacement: step 9, image 1 of 1
    • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
Robert Hobson
1,290 Reputation
9 Guides authored
Cal Poly, Team 1-11, Amido Winter 2011 Member of Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 Members
9 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 13
All Time: 7,420
