Shark Rotator NV502 Suction Hose Replacement
  1. Shark Rotator NV502 Suction Hose Replacement, Suction Hose: step 1, image 1 of 2 Shark Rotator NV502 Suction Hose Replacement, Suction Hose: step 1, image 2 of 2
    • Remove the bottom part of the hose from the vacuum by pressing on the tabs on each side of the nozzle.
  2. Shark Rotator NV502 Suction Hose Replacement: step 2, image 1 of 1
    • Remove the handle from the top of the vacuum with the suction hose attached.
  3. Shark Rotator NV502 Suction Hose Replacement: step 3, image 1 of 1
    • Remove the six 12 mm screws using the Phillips #2 screwdriver holding together the handle of the vacuum.
  4. Shark Rotator NV502 Suction Hose Replacement: step 4, image 1 of 3 Shark Rotator NV502 Suction Hose Replacement: step 4, image 2 of 3 Shark Rotator NV502 Suction Hose Replacement: step 4, image 3 of 3
    • Remove the cover of the handle.
    • Remove the suction hose from the handle.
Caroline Swanson
1,372 Reputation
3 Guides authored
Cal Poly, Team 4-3, Livingston Fall 2016 Member of Cal Poly, Team 4-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G3
4 Members
19 Guides authored
Past 24 Hours: 8
Past 7 Days: 34
Past 30 Days: 158
All Time: 80,959
