Introduction
This replacement guide uses a metal spudger, T20 Torx screwdriver, and a large plastic opening tool. This guide will show the user how to open the device casing, access the brush roll band, and replace the band.
CAUTION: Use care when using the metal spudger, as the edges of the tool are sharp and can cut you if you are not careful.
Press and slide the “access brush roll” buttons towards the text and lift plastic brush roll cover off.
Gently pry the circular screw cover off of the side of the casing with the shoe print mark on it with the small metal spudger.
Move to the side of the casing with the shoe print mark. Use the T20 screwdriver to unscrew the 18mm screw.
Use the large plastic opening tool to pry the rubber brushroll band towards you until the rubber brush roll band comes off of the small metal gear.
