Shark IONFlex 2X Brush Roll Band Replacement
  1. Shark IONFlex 2X Brush Roll Band Replacement, Brush Roll Band: step 1, image 1 of 1
    • Press and slide the “access brush roll” buttons towards the text and lift plastic brush roll cover off.
  2. Shark IONFlex 2X Brush Roll Band Replacement: step 2, image 1 of 2 Shark IONFlex 2X Brush Roll Band Replacement: step 2, image 2 of 2
    • Gently pry the circular screw cover off of the side of the casing with the shoe print mark on it with the small metal spudger.
  3. Shark IONFlex 2X Brush Roll Band Replacement: step 3, image 1 of 1
    • Use a T20 screwdriver to unscrew the 12.3 mm screw beneath the cover you just removed.
  4. Shark IONFlex 2X Brush Roll Band Replacement: step 4, image 1 of 2 Shark IONFlex 2X Brush Roll Band Replacement: step 4, image 2 of 2
    • Move to the side of the casing with the shoe print mark. Use the T20 screwdriver to unscrew the 18mm screw.
  5. Shark IONFlex 2X Brush Roll Band Replacement: step 5, image 1 of 3 Shark IONFlex 2X Brush Roll Band Replacement: step 5, image 2 of 3 Shark IONFlex 2X Brush Roll Band Replacement: step 5, image 3 of 3
    • Use the small metal spudger to gently separate the side casing from the main body.
  6. Shark IONFlex 2X Brush Roll Band Replacement: step 6, image 1 of 1
    • Use the large plastic opening tool to pry the rubber brushroll band towards you until the rubber brush roll band comes off of the small metal gear.
  7. Shark IONFlex 2X Brush Roll Band Replacement: step 7, image 1 of 2 Shark IONFlex 2X Brush Roll Band Replacement: step 7, image 2 of 2
    • Pull the rubber brush roll band out of the large white gear.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 44
All Time: 6,191
