Introduction
Your SHARK ION Robot Vacuum 750 has a nice and clean main brush, yet fails to clean the dirt along the way. You notice that the brush doesn't rotate appropriately. This malfunction may be due to the damage to the main brush motor inside. The tools requisite for this operation include a TORX T6 Screwdriver, a TORX T15 Screwdriver, and a Flathead #4 Screwdriver. You may want to check out our Outer Shell Replacement Guide to open up the internal parts.
Flip over the vacuum on a flat and uncluttered service with the bottom facing upwards.
Remove all seven 9.1mm Torx T15 screws from the deviceâs front bumper.
Remove the nine 9.1mm Torx T6 bolts from outer shell.
Remove the bolt to detach the motor by using the Phillips #0 screwdriver.
The motor is connected to the motherboard by this group of wires. Gently pull on the white plug to disconnect the wires.
