Shark ION Robot 750 Button Panel Replacement
    1. Shark ION Robot 750 Button Panel Replacement, Button Panel: step 1, image 1 of 2 Shark ION Robot 750 Button Panel Replacement, Button Panel: step 1, image 2 of 2
      • Before you begin, make sure the vacuum is off.
      • Use a spudger to remove the top case of the vacuum.
      • Flip over the top case.
      • Use tweezers or your hands to remove the center button panel from the socket.
      Ask FixBot
    2. Shark ION Robot 750 Button Panel Replacement: step 2, image 1 of 2 Shark ION Robot 750 Button Panel Replacement: step 2, image 2 of 2
      • Use your hands or tweezers to remove the other button panel from its socket.
      • Use a spudger to pop the panel off of the connector if you need help.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Ashley Nguyen
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 49
All Time: 336
