Introduction
If your vacuum will not turn on and the power cable/connector is faulty, use this guide to replace the power cable/connector. You will need wire strippers, wire end caps, and the T10 and T20 Torx Screwdrivers. Reassembly requires rewiring.
Pull up on the Dustbin Release button, and pull up on the handle to detach the dustbin.
Use the T20 screwdriver to remove the two 12 mm screws by turning counterclockwise.
Use the T20 screwdriver to remove the two 17 mm screws by turning counterclockwise.
Use the T20 screwdriver to remove the two 14 mm screws by turning counterclockwise.
Use the metal spudger to pry off the back panel.
There are 2 TT20 under the top silver cups
There are extra screws that need to be removed under the switches on the top which can be levered off. And then a couple extra screws under the top cover.
To reassemble your device, you must rewire a new power cord, then follow these instructions in reverse order.
6 other people completed this guide.
