Seville Classics MSC10166 Installing the PCB (Printing Circuit Board) Replacement
  1. Seville Classics MSC10166 Installing the PCB (Printing Circuit Board) Replacement, Installing the PCB (Printing Circuit Board): step 1, image 1 of 1
    • Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
    • Do this by unscrewing from left-to-right then pull the screws out of the back of the fan
  2. Seville Classics MSC10166 Installing the PCB (Printing Circuit Board) Replacement: step 2, image 1 of 1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely because it holds the wires.
  3. Seville Classics MSC10166 Installing the PCB (Printing Circuit Board) Replacement: step 3, image 1 of 1
    • Remove the Phillips (5-mm head) 6-mm screw that holds the circuit board to the outer shell of the fan.
    • Make sure the fan is unplugged while removing the circuit board as you may get shocked.
    • To remove the screws, unscrew in a left-to-right fashion at an angle to make sure that the wires do not get tangled.
  4. Seville Classics MSC10166 Installing the PCB (Printing Circuit Board) Replacement: step 4, image 1 of 1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the body of the fan.
  5. Seville Classics MSC10166 Installing the PCB (Printing Circuit Board) Replacement: step 5, image 1 of 2 Seville Classics MSC10166 Installing the PCB (Printing Circuit Board) Replacement: step 5, image 2 of 2
    • Remove the circuit board from the top cover. Do not touch the other side of the circuit board as you may damage circuit elements.
    • Unscrew the four screws on the top of the circuit board in a left-to-right fashion. After pull screws out of the board.
Mateo Begue
102 Reputation
2 Guides authored
Cal Poly, Team 15-46, Forte Fall 2012 Member of Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 1,507
