Sega CD CD Tray Replacement
  1. Sega CD CD Tray Replacement, Sega CD Plastic Housing Removal: step 1, image 1 of 2 Sega CD CD Tray Replacement, Sega CD Plastic Housing Removal: step 1, image 2 of 2
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Sega CD CD Tray Replacement: step 2, image 1 of 1
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Sega CD CD Tray Replacement: step 3, image 1 of 1
    • Slide the lock tab to the left to separate the halves of the console.
  4. Sega CD CD Tray Replacement: step 4, image 1 of 1
    • Lift from the left side to remove the top of the case.
  5. Sega CD CD Tray Replacement: step 5, image 1 of 1
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Sega CD CD Tray Replacement: step 6, image 1 of 1
    • Lift the top of the case to remove the cover.
  7. Sega CD CD Tray Replacement: step 7, image 1 of 1
    • Remove the faceplate by pulling it up, then out.
  8. Sega CD CD Tray Replacement, CD Tray: step 8, image 1 of 2 Sega CD CD Tray Replacement, CD Tray: step 8, image 2 of 2
    • Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate.
    • The three screws are shown on the diagram.
  9. Sega CD CD Tray Replacement: step 9, image 1 of 2 Sega CD CD Tray Replacement: step 9, image 2 of 2
    • Remove the two screws from the plastic bar.
    • The two screws are shown pictured.
  10. Sega CD CD Tray Replacement: step 10, image 1 of 2 Sega CD CD Tray Replacement: step 10, image 2 of 2
    • To remove the CD tray
    • Remove the four screws with the Phillips head screwdriver.
  11. Sega CD CD Tray Replacement: step 11, image 1 of 1
    • Carefully unplug the wire connected to optical reader.
  12. Sega CD CD Tray Replacement: step 12, image 1 of 3 Sega CD CD Tray Replacement: step 12, image 2 of 3 Sega CD CD Tray Replacement: step 12, image 3 of 3
    • Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver.
    • The four screws are highlighted on the diagram.
    • The four springs below the circuit board are attached to the screws, so be careful not to lose them when you remove the screws.
  13. Sega CD CD Tray Replacement: step 13, image 1 of 1
    • Carefully remove the CD tray from circuit board.
sskyllin
21 Reputation
2 Guides authored
Cal Poly, Team 5-14, Maness Fall 2010 Member of Cal Poly, Team 5-14, Maness Fall 2010
CPSU-MANESS-F10S5G14
4 Members
12 Guides authored
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 39
All Time: 9,600
