Shop the Holiday Gift Guide
Screen Components Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
0
All Time:
37
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
  • Spudger
    4.9
    1. Screen Components Removal, Transfer screen parts: step 1, image 1 of 3 Screen Components Removal, Transfer screen parts: step 1, image 2 of 3 Screen Components Removal, Transfer screen parts: step 1, image 3 of 3
      • Compare your replacement screen to the original. You may need to transfer the following parts:
      • The skinny board located near the bottom right of the screen.
      • Two S shaped screen cables attached to the original screen.
      • If your replacement screen comes with these parts installed, you can skip down to the adhesive removal step.
      Ask FixBot
    2. Screen Components Removal, Remove the screen cable cover: step 2, image 1 of 3 Screen Components Removal, Remove the screen cable cover: step 2, image 2 of 3 Screen Components Removal, Remove the screen cable cover: step 2, image 3 of 3
      • Use the point of a spudger to pry up and unclip the screen cable's metal cover.
      • Be careful not to deform the cover too much, as you'll need to reinstall it during reassembly.
      • Remove the cover.
      Ask FixBot
    3. Screen Components Removal, Disconnect the screen cable: step 3, image 1 of 3 Screen Components Removal, Disconnect the screen cable: step 3, image 2 of 3 Screen Components Removal, Disconnect the screen cable: step 3, image 3 of 3
      • Use a spudger to pry up and disconnect the screen cable press connector, starting on one of the short sides and moving to the other.
      Ask FixBot
    4. Screen Components Removal: step 4, image 1 of 1
      • Remove the cable and set it aside—you'll install it on your new screen later.
      Ask FixBot
    5. Screen Components Removal, Remove the board cover: step 5, image 1 of 3 Screen Components Removal, Remove the board cover: step 5, image 2 of 3 Screen Components Removal, Remove the board cover: step 5, image 3 of 3
      • Use the point of a spudger to pry up and unclip the edges of the metal cover on the board (near the bottom right of the screen).
      • Remove the cover.
      Ask FixBot
    6. Screen Components Removal, Disconnect the board: step 6, image 1 of 3 Screen Components Removal, Disconnect the board: step 6, image 2 of 3 Screen Components Removal, Disconnect the board: step 6, image 3 of 3
      • Use the flat end of a spudger to lift the hinged, locking flaps on the board's two ZIF connectors.
      Ask FixBot
    7. Screen Components Removal: step 7, image 1 of 3 Screen Components Removal: step 7, image 2 of 3 Screen Components Removal: step 7, image 3 of 3
      • Use the point of a spudger to slide both cables completely out of their sockets.
      • You can leave the ribbon cable connected to the top edge of the board, since you're going to be transferring it.
      Ask FixBot
    8. Screen Components Removal, Remove the board: step 8, image 1 of 3 Screen Components Removal, Remove the board: step 8, image 2 of 3 Screen Components Removal, Remove the board: step 8, image 3 of 3
      • Mild adhesive secures the board to the screen.
      • Slide the flat end of a spudger under the board and lift to remove it.
      Ask FixBot
Finish Line
Spencer Day
210,392 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 37
