Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement
  1. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement, Battery: step 1, image 1 of 1
    • Place the computer upside down, with the battery pack facing away from you.
  2. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: step 2, image 1 of 2 Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: step 2, image 2 of 2
    • Remove the battery by pushing out the locks on either end then pushing the battery away from you.
  3. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement, Panel: step 3, image 1 of 1
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw on the ODD/HDD Memory panel.
  4. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: step 4, image 1 of 2 Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: step 4, image 2 of 2
    • Pull the panel towards you to release it, then lift it off the computer.
  5. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: step 5, image 1 of 1
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw next to the label “ODD."
    • Remove the three 4.5mm screws from around the memory drive nest.
  6. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: step 6, image 1 of 1
    • Using the J1 Japanese Industrial Standard screwdriver, remove the thirteen 9.5mm screws from the panel that cover the bottom of the computer.
  7. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: step 7, image 1 of 3 Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: step 7, image 2 of 3 Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: step 7, image 3 of 3
    • Begin removing the computer casing by prying beside the disk drive with the iFixit opening tool and the spudger, working counterclockwise.
    • Lift the panel from the computer.
  8. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement, Disc Drive: step 8, image 1 of 1
    • Remove the disc drive by pulling it towards the outside of the computer.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 346
