Introduction
This guide outlines the simple steps required to remove the disc drive from the computer. Simply do what the guide tells you, and the disc drive will easily come off the computer.
Remove the battery by pushing out the locks on either end then pushing the battery away from you.
Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw on the ODD/HDD Memory panel.
Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw next to the label “ODD."
Remove the three 4.5mm screws from around the memory drive nest.
Using the J1 Japanese Industrial Standard screwdriver, remove the thirteen 9.5mm screws from the panel that cover the bottom of the computer.
Begin removing the computer casing by prying beside the disk drive with the iFixit opening tool and the spudger, working counterclockwise.
Lift the panel from the computer.
