Samsung SCH-U340 Logic Board Assembly Replacement
  1. Samsung SCH-U340 Logic Board Assembly Replacement, Battery: step 1, image 1 of 1
    • Turn the cell phone so that the back side is facing you.
    • Press the upper indent and slide the back cover down.
  2. Samsung SCH-U340 Logic Board Assembly Replacement: step 2, image 1 of 1
    • Pull the battery up from indent at the bottom and slide it out.
  3. Samsung SCH-U340 Logic Board Assembly Replacement: step 3, image 1 of 1
    • Set the battery aside.
  4. Samsung SCH-U340 Logic Board Assembly Replacement, Top Casing: step 4, image 1 of 1
    • The outer casing consists of two separate parts on the upper and lower halves of the device. The upper outer casing is held on through a combination of screws and tabs.
    • First, remove the plastic plugs covering the screws with a spudger.
  5. Samsung SCH-U340 Logic Board Assembly Replacement: step 5, image 1 of 1
    • Underneath the plugs are two small screws that can be removed with a small Phillips screwdriver.
    • The screws will need to be pried out after unscrewing them due to their size.
    • Take care not to lose the screws as they are small and have a tendency to roll.
  6. Samsung SCH-U340 Logic Board Assembly Replacement: step 6, image 1 of 1
    • The outer cover is now secured with seven tabs: one large tab (marked in red) and seven smaller tabs (marked in orange).
    • To begin removing the outer cover, start by prying the large tab up with a flat object.
    • See next slide for details for smaller tabs.
  7. Samsung SCH-U340 Logic Board Assembly Replacement: step 7, image 1 of 1
    • Continue to pry each smaller tab up, taking care not to break the tabs.
    • If disaster strikes and a tab is broken, the outer casing can still be put back on assuming the majority of the tabs are still intact.
  8. Samsung SCH-U340 Logic Board Assembly Replacement: step 8, image 1 of 1
    • After the last tab is removed, tug gently on the outer casing to remove it.
    • Don't pull too hard, or you may damage the wires connected to the speaker.
  9. Samsung SCH-U340 Logic Board Assembly Replacement, Lower Casing: step 9, image 1 of 1
    • The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
  10. Samsung SCH-U340 Logic Board Assembly Replacement: step 10, image 1 of 2 Samsung SCH-U340 Logic Board Assembly Replacement: step 10, image 2 of 2
    • Use a spudger to pry the back assembly off of the device.
  11. Samsung SCH-U340 Logic Board Assembly Replacement, Logic Board Assembly: step 11, image 1 of 1
    • Use spudger to pry logic board from the casing.
  12. Samsung SCH-U340 Logic Board Assembly Replacement: step 12, image 1 of 1
    • Rotate the logic board assembly out of the casing, being careful not to break VGA cable.
  13. Samsung SCH-U340 Logic Board Assembly Replacement: step 13, image 1 of 1
    • Lift the number pad straight up from the casing.
  14. Samsung SCH-U340 Logic Board Assembly Replacement: step 14, image 1 of 1
    • Set the number pad to the side.
Mitchell Walker
25 Reputation
2 Guides authored
Cal Poly, Team 3-21, Maness Winter 2010 Member of Cal Poly, Team 3-21, Maness Winter 2010
CPSU-MANESS-W10S3G21
4 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 3,492
