Samsung NX300 and NX300M Back Panel Assembly Replacement
  1. Samsung NX300 and NX300M Back Panel Assembly Replacement, Unscrew the Back Panel: step 1, image 1 of 2 Samsung NX300 and NX300M Back Panel Assembly Replacement, Unscrew the Back Panel: step 1, image 2 of 2
    • Using a Phillips #00 precision screwdriver, remove the seven 4mm screws (5 on the bottom of the device and 1 on each of the two sides) holding the back panel to the camera.
    • On the NX300M model, there is an additional screw under the text AMOLED behind display which should be removed before detaching the back panel of the camera.
  2. Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Input Port Screw: step 2, image 1 of 1
    • Using a Phillips #00 precision screwdriver, remove the last 4 mm screw located inside the input ports' compartment.
  3. Samsung NX300 and NX300M Back Panel Assembly Replacement, Open the Camera Casing: step 3, image 1 of 3 Samsung NX300 and NX300M Back Panel Assembly Replacement, Open the Camera Casing: step 3, image 2 of 3 Samsung NX300 and NX300M Back Panel Assembly Replacement, Open the Camera Casing: step 3, image 3 of 3
    • Place a plastic opening tool into the gap between the back panel and camera body, from both the top and the bottom of camera. Carefully pry open the camera and separate the back panel.
  4. Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Back Panel: step 4, image 1 of 3 Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Back Panel: step 4, image 2 of 3 Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Back Panel: step 4, image 3 of 3
    • Using tweezers or your fingers, pull the display's black ribbon from the motherboard. This frees the back panel altogether.
    • To safely remove ribbons, you would need to first unlock the holding mechanism by lifting up the black strip atop the ribbon adapter.
11 other people completed this guide.
Andres Perez
951 Reputation
5 Guides authored
USF Tampa, Team 9-6, Blackwell Winter 2015 Member of USF Tampa, Team 9-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G6
4 Members
10 Guides authored
2 Comments
I had to replace the back panel when my amoled screen started going bad. Thanks for a great tutorial!
Amanda Aiken - Reply
Hello, can anybody tell me if the display of SAMSUNG NX 300 M match to a SAMSUNG NX 300 ? I need to replace the display of NX 300 and i dont find any pieces but i found an NX 300 M
Norbert - Ciprian Patras - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 4,997
