Samsung NX1 Back Cover Replacement
  1. Samsung NX1 Back Cover Replacement, Viewfinder Focus Dial: step 1, image 1 of 2 Samsung NX1 Back Cover Replacement, Viewfinder Focus Dial: step 1, image 2 of 2
    • Push the rubber viewfinder grip upward.
  2. Samsung NX1 Back Cover Replacement: step 2, image 1 of 2 Samsung NX1 Back Cover Replacement: step 2, image 2 of 2
    • Use the Phillips #00 screwdriver to remove one 6.4 mm screw in the center of the dial.
    • Remove the dial by lifting upward with your fingers.
  3. Samsung NX1 Back Cover Replacement, Back Cover: step 3, image 1 of 3 Samsung NX1 Back Cover Replacement, Back Cover: step 3, image 2 of 3 Samsung NX1 Back Cover Replacement, Back Cover: step 3, image 3 of 3
    • Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
    • Use your fingers to lift the plastic viewfinder cover upward.
  4. Samsung NX1 Back Cover Replacement: step 4, image 1 of 2 Samsung NX1 Back Cover Replacement: step 4, image 2 of 2
    • Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
  5. Samsung NX1 Back Cover Replacement: step 5, image 1 of 1
    • Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
  6. Samsung NX1 Back Cover Replacement: step 6, image 1 of 1
    • Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
    • Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
  7. Samsung NX1 Back Cover Replacement: step 7, image 1 of 3 Samsung NX1 Back Cover Replacement: step 7, image 2 of 3 Samsung NX1 Back Cover Replacement: step 7, image 3 of 3
    • Use a plastic opening tool to separate the back cover from the front cover.
    • Pry the back cover in this order: bottom, right side, left side.
  8. Samsung NX1 Back Cover Replacement: step 8, image 1 of 2 Samsung NX1 Back Cover Replacement: step 8, image 2 of 2
    • Use your fingers to pull the back cover away from the front cover.
    • Do not completely separate the back cover from the front cover as two cables hold these components together.
  9. Samsung NX1 Back Cover Replacement: step 9, image 1 of 3 Samsung NX1 Back Cover Replacement: step 9, image 2 of 3 Samsung NX1 Back Cover Replacement: step 9, image 3 of 3
    • Use tweezers to pull the two ribbon cables horizontally out of their clips.
Hannah Patrick
891 Reputation
6 Guides authored
USF Tampa, Team 1-4, Leahy Spring 2016 Member of USF Tampa, Team 1-4, Leahy Spring 2016
USFT-LEAHY-S16S1G4
3 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 13
All Time: 983
