Introduction
This guide gives you a look at the major components of the Samsung NX Mini and provides complete disassembly instructions.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
Orient the camera so the button panel and LCD are facing you.
Use a spudger or fingernail to open the battery compartment on the right side of the camera.
Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
Remove the 4 mm Phillips #00 screw hiding in the external flash port.
Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
Use a Phillips #00 screwdriver to remove the 3 mm screw located below the wifi antenna.
Use a Phillips #00 screwdriver to remove the two 5 mm screws holding the flash assembly to the camera case.
Remove the three 4 mm Phillips #00 screws securing the button panel to the camera case.
3 other people completed this guide.
4 Comments
do you have any nx mini device software tricks or hacks? (Video time limit or no lens error or anything)
Any experiences to change the LCD ?
This camera could be so much better if Samsung adds flash with manual mode when using vintage lenses. Is there any way to get camera to fire flash?
If Samsung just added a toggle option on/off that would be great. If there was a way to control intensity of the flash then even better. It is standard on Nikon 1 camera.
