Introduction
This guide provides detailed steps to remove and replace the device's Optical Drive in the Samsung NP700Z5AH device.
Wedge your fingers in between the upper case and the lower case
Gently pull the lower case away from the upper case to remove it
Using your fingers, grasp the ribbon cable connected to the optical drive and pull it straight out to disconnect it.
Using the Phillips#00 remove the three 3.5mm screws that secure the speaker to the bottom case.
With your fingers, grasp the edges of the speaker and slide it up and away from the fan to lift it out of the case.
With the Phillips#00, remove the following screws holding the optical drive to the metal brackets.
Six 2.4mm screws
One 3.4mm screw
Using your fingers, grasp the metal brackets and remove them.
Place your fingers on either side of the optical drive and slide it away from the fan to remove it.
