Samsung NP-N102S-B05PH Hard Drive Replacement
  1. Samsung NP-N102S-B05PH Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Start off by powering down your laptop, equipping your anti-static wrist strap, and positioning your laptop upside-down.
  2. Samsung NP-N102S-B05PH Hard Drive Replacement: step 2, image 1 of 1
    • Remove the assortment of 6.5mm Phillips #0 screws labeled in the picture.
  3. Samsung NP-N102S-B05PH Hard Drive Replacement: step 3, image 1 of 1
    • Now it's time to break out your blue opening tool! Pry off the bottom cover, which is now attached only by plastic clasps.
  4. Samsung NP-N102S-B05PH Hard Drive Replacement: step 4, image 1 of 3 Samsung NP-N102S-B05PH Hard Drive Replacement: step 4, image 2 of 3 Samsung NP-N102S-B05PH Hard Drive Replacement: step 4, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the four 4.5mm bracket screws holding the hard drive onto the motherboard.
    • Take care not to remove the screws holding the bracket to the motherboard, as you will need that bracket to attach the next hard drive.
  5. Samsung NP-N102S-B05PH Hard Drive Replacement: step 5, image 1 of 3 Samsung NP-N102S-B05PH Hard Drive Replacement: step 5, image 2 of 3 Samsung NP-N102S-B05PH Hard Drive Replacement: step 5, image 3 of 3
    • Last, lift up the hard drive and gently pull off the SATA cable that is currently connected to the board. The hard drive is now fully removed from the laptop.
Daniel Rudzik
349 Reputation
3 Guides authored
USF Tampa, Team 2-4, Nance Fall 2016 Member of USF Tampa, Team 2-4, Nance Fall 2016
USFT-NANCE-F16S2G4
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 1,583
