Introduction
In this guide, we will open up the back case of the laptop and replace the hard drive. Replacing the hard drive is a quick way to solve any issues resulting from common hard drive issues including; a slow startup, random crashes, corrupted files, and problems with opening files and media. A faulty drive can result from many things, including running at total or near-full capacity.
If the original hard drive has been tested to be causing issues, it's a good idea to replace it and possibly upgrade storage capacity.
Note: Before replacing a hard drive, it is a good idea to have a backup of files stored on it, if files are needed to be recovered afterward.
Start off by powering down your laptop, equipping your anti-static wrist strap, and positioning your laptop upside-down.
Now it's time to break out your blue opening tool! Pry off the bottom cover, which is now attached only by plastic clasps.
Use a Phillips #0 screwdriver to remove the four 4.5mm bracket screws holding the hard drive onto the motherboard.
Take care not to remove the screws holding the bracket to the motherboard, as you will need that bracket to attach the next hard drive.
Last, lift up the hard drive and gently pull off the SATA cable that is currently connected to the board. The hard drive is now fully removed from the laptop.
