Introduction
In this guide, we will open up the back case of the laptop and replace the hard drive.
Start off by powering down your laptop, equipping your anti-static wrist strap, and positioning your laptop upside-down.
Now it's time to break out your blue opening tool! Pry off the bottom cover, which is now attached only by plastic clasps.
Use a Phillips #0 screwdriver to remove the four 4.5mm bracket screws holding the hard drive onto the motherboard.
Take care not to remove the screws holding the bracket to the motherboard, as you will need that bracket to attach the next hard drive.
Last, lift up the hard drive and gently pull off the SATA cable that is currently connected to the board. The hard drive is now fully removed from the laptop.
