Samsung NP-N102S-B05PH Display Replacement
  1. Samsung NP-N102S-B05PH Display Replacement, Display: step 1, image 1 of 3 Samsung NP-N102S-B05PH Display Replacement, Display: step 1, image 2 of 3 Samsung NP-N102S-B05PH Display Replacement, Display: step 1, image 3 of 3
    • Take out the four 4.5mm Phillips #0 screws located at the corners of the screen.
  2. Samsung NP-N102S-B05PH Display Replacement: step 2, image 1 of 2 Samsung NP-N102S-B05PH Display Replacement: step 2, image 2 of 2
    • Now, use the blue opening tool to gently pry the front bezel off.
  3. Samsung NP-N102S-B05PH Display Replacement: step 3, image 1 of 3 Samsung NP-N102S-B05PH Display Replacement: step 3, image 2 of 3 Samsung NP-N102S-B05PH Display Replacement: step 3, image 3 of 3
    • Unscrew each of the four 6.5mm Phillips #0 screws securing the screen to the case.
  4. Samsung NP-N102S-B05PH Display Replacement: step 4, image 1 of 3 Samsung NP-N102S-B05PH Display Replacement: step 4, image 2 of 3 Samsung NP-N102S-B05PH Display Replacement: step 4, image 3 of 3
    • Using the black spudger tool and your fingertip, gently push on the ends of the ribbon cable to pop it out of the socket.
  5. Samsung NP-N102S-B05PH Display Replacement: step 5, image 1 of 1
    • The screen is can now be lifted away from the laptop.
Daniel Rudzik
349 Reputation
3 Guides authored
USF Tampa, Team 2-4, Nance Fall 2016 Member of USF Tampa, Team 2-4, Nance Fall 2016
USFT-NANCE-F16S2G4
4 Members
5 Guides authored
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 29
All Time: 764
