Samsung Level Box Mini Battery Replacement
  1. Samsung Level Box Mini Battery Replacement, Battery: step 1, image 1 of 2 Samsung Level Box Mini Battery Replacement, Battery: step 1, image 2 of 2
    • Using a plastic opening tool, go around the edges of the rubber bottom. Insert the same tool under the edge of the rubber and swivel side to side. Continue moving it forward while peeling the plastic off with the precision tweezers.
  2. Samsung Level Box Mini Battery Replacement: step 2, image 1 of 1
    • Remove the six 4.5 mm Philips #1 screws from the bottom plate using the Screwdriver J00. Take off the bottom plate.
  3. Samsung Level Box Mini Battery Replacement: step 3, image 1 of 1
    • Using the plastic opening tool, remove the batteries from the device.
dylan weiss
134 Reputation
1 Guide authored
USF Tampa, Team 1-4, Kass Spring 2017 Member of USF Tampa, Team 1-4, Kass Spring 2017
USFT-KASS-S17S1G4
5 Members
3 Guides authored
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 56
All Time: 8,467
