Samsung Gear Fit Screen Replacement
  1. Samsung Gear Fit Screen Replacement, Watch Band: step 1, image 1 of 2 Samsung Gear Fit Screen Replacement, Watch Band: step 1, image 2 of 2
    • Place your thumbs on the ends of the screen.
    • Push the watch outward while pulling the band away from the watch.
  2. Samsung Gear Fit Screen Replacement, Screen: step 2, image 1 of 1
    • Heating the device with a hair dryer may warp the screen or damage the device. It it preferable to use an iOpener for this step.
    • For step-by-step instructions on using an iOpener, see the iOpener Instructions.
    • Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
  3. Samsung Gear Fit Screen Replacement: step 3, image 1 of 3 Samsung Gear Fit Screen Replacement: step 3, image 2 of 3 Samsung Gear Fit Screen Replacement: step 3, image 3 of 3
    • The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful.
    • Gently pry the screen loose using a plastic opening tool.
    • If the screen doesn't easily come loose, more heating may be required
  4. Samsung Gear Fit Screen Replacement: step 4, image 1 of 3 Samsung Gear Fit Screen Replacement: step 4, image 2 of 3 Samsung Gear Fit Screen Replacement: step 4, image 3 of 3
    • Using tweezers as a lever, pry the inner assembly out of the external casing.
    • This will be harder than removing the screen. Moderate force may be required.
  5. Samsung Gear Fit Screen Replacement: step 5, image 1 of 3 Samsung Gear Fit Screen Replacement: step 5, image 2 of 3 Samsung Gear Fit Screen Replacement: step 5, image 3 of 3
    • Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
  6. Samsung Gear Fit Screen Replacement: step 6, image 1 of 2 Samsung Gear Fit Screen Replacement: step 6, image 2 of 2
    • Gently peel the screen assembly up and away from the device using tweezers.
Nathan Powell
1,577 Reputation
3 Guides authored
Cal Poly, Team 11-49, Amido Spring 2014 Member of Cal Poly, Team 11-49, Amido Spring 2014
CPSU-AMIDO-S14S11G49
4 Members
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 53,447
