Introduction
Getting to the battery requires disassembling the entire device, but the battery itself is easy to remove.
Place your thumbs on the ends of the screen.
Push the watch outward while pulling the band away from the watch.
Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
Using tweezers as a lever, pry the inner assembly out of the external casing.
This will be harder than removing the screen. Moderate force may be required.
Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
Three ribbon cables hold the motherboard to the rest of the assembly.
The battery cable in the front.
And two on the side.
Using a pair of tweezers, carefully pull each connector away to disconnect it from the rest of the assembly.
The motherboard is a segmented three piece construction.
Use tweezers to first lift up, with a moderate amount of force, and free each ends of the motherboard from the assembly.
The motherboard should now be removable from the assembly.
Use tweezers to lightly pry, lift, and remove the board by its middle section.
With the motherboard removed, the battery is exposed.
A small metal strut protects the battery.
Remove the small metal strut by prying it out of both sides of the enclosure.
Remove the battery by pulling on the pull tab.
Don't be afraid to use force, the battery is tightly packed into the plastic enclosure.
