Samsung Galaxy Tab S3 Headphone Jack Replacement
  1. Samsung Galaxy Tab S3 Headphone Jack Replacement, Display: step 1, image 1 of 1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Samsung Galaxy Tab S3 Headphone Jack Replacement: step 2, image 1 of 1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
  3. Samsung Galaxy Tab S3 Headphone Jack Replacement: step 3, image 1 of 1
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
  4. Samsung Galaxy Tab S3 Headphone Jack Replacement: step 4, image 1 of 3 Samsung Galaxy Tab S3 Headphone Jack Replacement: step 4, image 2 of 3 Samsung Galaxy Tab S3 Headphone Jack Replacement: step 4, image 3 of 3
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3 Headphone Jack Replacement, Rear glass panel: step 5, image 1 of 2 Samsung Galaxy Tab S3 Headphone Jack Replacement, Rear glass panel: step 5, image 2 of 2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
  6. Samsung Galaxy Tab S3 Headphone Jack Replacement, Battery: step 6, image 1 of 2 Samsung Galaxy Tab S3 Headphone Jack Replacement, Battery: step 6, image 2 of 2
    • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
  7. Samsung Galaxy Tab S3 Headphone Jack Replacement: step 7, image 1 of 1
    • The midframe should snap off from the device’s motherboard.
  8. Samsung Galaxy Tab S3 Headphone Jack Replacement: step 8, image 1 of 3 Samsung Galaxy Tab S3 Headphone Jack Replacement: step 8, image 2 of 3 Samsung Galaxy Tab S3 Headphone Jack Replacement: step 8, image 3 of 3
    • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
  9. Samsung Galaxy Tab S3 Headphone Jack Replacement: step 9, image 1 of 2 Samsung Galaxy Tab S3 Headphone Jack Replacement: step 9, image 2 of 2
    • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
  10. Samsung Galaxy Tab S3 Headphone Jack Replacement: step 10, image 1 of 2 Samsung Galaxy Tab S3 Headphone Jack Replacement: step 10, image 2 of 2
    • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
  11. Samsung Galaxy Tab S3 Headphone Jack Replacement: step 11, image 1 of 1
    • The battery should now be removed and detached from the device.
  12. Samsung Galaxy Tab S3 Headphone Jack Replacement, Headphone Jack: step 12, image 1 of 3 Samsung Galaxy Tab S3 Headphone Jack Replacement, Headphone Jack: step 12, image 2 of 3 Samsung Galaxy Tab S3 Headphone Jack Replacement, Headphone Jack: step 12, image 3 of 3
    • Insert the pointy end of the spudger into the headphone jack.
    • Lift the spudger up to snap the headphone jack module off of the motherboard.
    • Be careful to avoid inserting the spudger too far or applying excessive force, as this may damage the inside of the headphone jack.
  13. Samsung Galaxy Tab S3 Headphone Jack Replacement: step 13, image 1 of 2 Samsung Galaxy Tab S3 Headphone Jack Replacement: step 13, image 2 of 2
    • Use the flat end of the spudger to snap the ribbon connector off of the motherboard.
  14. Samsung Galaxy Tab S3 Headphone Jack Replacement: step 14, image 1 of 1
    • Remove the headphone jack from the device.
Mimi Fucini
684 Reputation
4 Guides authored
Cal Poly, Team S22-G4, Maness Spring 2018 Member of Cal Poly, Team S22-G4, Maness Spring 2018
CPSU-MANESS-S18S22G4
5 Members
15 Guides authored
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 11
All Time: 850
