Samsung Galaxy Tab S3 Battery Replacement
  1. Samsung Galaxy Tab S3  Battery Replacement, Display: step 1, image 1 of 1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Samsung Galaxy Tab S3  Battery Replacement: step 2, image 1 of 1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
  3. Samsung Galaxy Tab S3  Battery Replacement: step 3, image 1 of 1
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
  4. Samsung Galaxy Tab S3  Battery Replacement: step 4, image 1 of 3 Samsung Galaxy Tab S3  Battery Replacement: step 4, image 2 of 3 Samsung Galaxy Tab S3  Battery Replacement: step 4, image 3 of 3
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3  Battery Replacement, Rear glass panel: step 5, image 1 of 2 Samsung Galaxy Tab S3  Battery Replacement, Rear glass panel: step 5, image 2 of 2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
  6. Samsung Galaxy Tab S3  Battery Replacement, Battery: step 6, image 1 of 2 Samsung Galaxy Tab S3  Battery Replacement, Battery: step 6, image 2 of 2
    • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
  7. Samsung Galaxy Tab S3  Battery Replacement: step 7, image 1 of 1
    • The midframe should snap off from the device’s logic board.
  8. Samsung Galaxy Tab S3  Battery Replacement: step 8, image 1 of 3 Samsung Galaxy Tab S3  Battery Replacement: step 8, image 2 of 3 Samsung Galaxy Tab S3  Battery Replacement: step 8, image 3 of 3
    • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
  9. Samsung Galaxy Tab S3  Battery Replacement: step 9, image 1 of 2 Samsung Galaxy Tab S3  Battery Replacement: step 9, image 2 of 2
    • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
  10. Samsung Galaxy Tab S3  Battery Replacement: step 10, image 1 of 2 Samsung Galaxy Tab S3  Battery Replacement: step 10, image 2 of 2
    • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
  11. Samsung Galaxy Tab S3  Battery Replacement: step 11, image 1 of 1
    • The battery should now be removed and detached from the device.
Mimi Fucini
684 Reputation
4 Guides authored
Cal Poly, Team S22-G4, Maness Spring 2018 Member of Cal Poly, Team S22-G4, Maness Spring 2018
CPSU-MANESS-S18S22G4
5 Members
15 Guides authored
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 217
All Time: 23,793
