Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement
  1. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement, Screen: step 1, image 1 of 2 Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement, Screen: step 1, image 2 of 2
    • Apply the heat gun around the edges of the tablet to melt the adhesive glue.
    • Do not allow the gun to remain still for more than two seconds, so that you do not melt the plastic around the screen.
    • If you do not have access to a heat gun, you may also use an iOpener or a hair dryer. Refer to the iOpener guide for extra help.
  2. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement: step 2, image 1 of 2 Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement: step 2, image 2 of 2
    • Apply the suction to the bottom or top right corner.
    • Use the plastic opening tool at several points around the screen while the suction is being applied to pop the screen out.
  3. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement: step 3, image 1 of 1
    • Once the screen is detached, open the tablet like a book.
    • Gently open the tablet, and do not pull the pieces apart since you can risk damaging the orange ribbon cable.
  4. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Using the precision tweezers, remove the silver tape that is holding the orange ribbon cable connecting the two pieces.
  5. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement: step 5, image 1 of 1
    • Using the precision tweezers, remove the small press-fit connector from the body of the tablet.
  6. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement, Screws: step 6, image 1 of 2 Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement, Screws: step 6, image 2 of 2
    • Using the Philips #000 screwdriver, remove the seventeen 2.74 mm screws around the edges.
    • Remove the two 2.74 mm black screws in the middle of the tablet with the Philips #000 screwdriver.
    • Put the screws on a magnetic project mat or in a container so that you do not lose them.
  7. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement: step 7, image 1 of 3 Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement: step 7, image 2 of 3 Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement: step 7, image 3 of 3
    • Take the plastic opening tool around the tablet to remove the motherboard from the device.
  8. Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement, SIM Card Holder: step 8, image 1 of 2 Samsung Galaxy Tab S2 9.7 AT&T SIM Card Holder Replacement, SIM Card Holder: step 8, image 2 of 2
    Buy
    • Locate the SIM card and the memory card holders along the right side of the tablet.
    • Using the precision tweezers, remove the SIM card and memory card holders.
Joy Harris
826 Reputation
7 Guides authored
USF Tampa, Team S3-G4, Sullivan Spring 2017 Member of USF Tampa, Team S3-G4, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G4
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 863
